Where the long/middle branch out from the short (at the big turn at the bottom of the little descent part) is where trail maintenance seems to have ended a while ago. I'm pretty sure that there are downed trees still across the trail from hurricane ivan, its definitely rideable but a little frustrating. I did see that someone had a chainsaw fairly deep in there not too long ago though, so we may be in luck.
Just so that we're clear, when you say destroyed, do you mean when they "destroyed" it several years back from logging, or just last year when they graveled off a bunch of the backside, graded out all the water bars, destroyed all the 8 ft high berms, gated off both ends of the descent, and generally face****ed the trail into oblivion?
If you mean the former rather than the latter, you'll be in for a surprise the next time you're out riding it. Its still a good bang for the buck trail when I just want to go pedal for an hour or two after work, but the only time I'm on that trail anymore for a good trail experience is when I'm using it to connect to other trails around.
