I'm having problems upshifting from the granny to the middle ring.
When I upshift from the granny, the FD cage seem to move fine but the
chain stays in the granny and rubs the cage's inner plate. When I do another upshift,
the chain transfers to the big ring(skips the middle altogether) but still rubs the cage's inner plate. Then with a downshift from the big ring, the chain finally makes it to the middle ring without rubbing the cage.
In a nutshell, I have to do 2 upshifts and 1 downshift just to get from granny to middle
ring. A couple weeks ago, this behavior happens only under load.
I tried adjusting the cable tension via the FD bolt and barrel adjusters but the problem
persists.
FWIW, I didn't do any changes to the drivetrain and I'm using XT shifters and crankset. Downshifting to any of the smaller rings are alright, though.
Any ideas on how to fix this?
Thanks in advance!
persists.
Thanks in advance!
