i've got 2 cranksets on 2 different bikes, both use the same bolt patterns (truvativ stylo, and stock redline d440 crank made by RPM)
on the center ring the chainrings don't sit properly, they seem to have a different "cut" at the edges so they don't lay flat against the crank... my thoughts are this notching is to distribute the pressure away from the little bolts and apply it to the crankset itself...
so the question is... would it be safe to take a file to the chainrings to get them to sit properly or is that a no-no...
and 2nd question... if i buy an aftermarket ring, will I have the same problem?
figured you guys would know
thanks
mark
thanks
mark
