I mostly ride in Delaware (primarily Brandywine) and am looking for tire recommendations for my new 29 FS trail bike. The bike is used and came with Nobby Nics, 2.35 front / 2.25 rear. The rear is showing lots of fluid leaking through small punctures so I plan on moving the 2.35 to the rear and replacing the front tire with something new. I am an intermediate rider and need a tire with some sort of transition knobs, as I lean in some in turns but not super aggressively. (I dont like the Ardent up front due to the sketchiness in this mid lean) Rim inner width is 22.5mm, so I am not looking for anything bigger than 2.4 or anything designed for wide rims. Also not looking for anything that will sap too much of the snappiness from the bike. I currently run Forekasters 2.35 on my Hardtail or a Forekaster front / Ardent Rear. The Forekasters have been great but I am interested in something just a bit more grippy/supple.
Tires I am considering:
DHRII 2.3 - Should be good grip and weight isnt too bad. Concerned about mud shedding and possible transitions knobs. Maybe to much drag (rolling resistance due to blocky barely ramped center knobs)
XR4 2.4 - Seems like good grip, supple and good weight. Concerned about sidewall durability and designed around wide rims.
Aggressor 2.3 - Seems like a good in between tire.I can find almost no good info on this as a Front tire. Maybe that should be a hint.
New Hans Dampf (HS491) 2.4 - Looks like a good tread pattern and good rubber compound. Expensive, designed around wide rims, maybe too much drag.
Tire choice around here is tricky. Dirt is usually great but need to survive pointy rocks and wet roots. Don't want to pack with mud but also don't want to drag an enduro tire's weight and big knobs up all the punchy hills. What am I missing? What do you guys run?
