Hello all,
I was using two michelin country at (2.0) tires, and thought I wanted something a little bigger on the front. The tread pattern is the same as the XCR AT.
At sea otter, I bought 2 michelin UST tires, the xtreme at and the xcr at. The rep said that was a good combo, with the xtreme up front. I have not mounted these yet.
I recently bought an Xtreme non-ust tire and mated it to one of the country at tires, with the country in the rear. While the combo seemed to work well, I believe the xtreme is narrower than the country, even though it is more knobby.
My question is, does anyone run this combo? What are your thoughts? Should I be running the xtreme in the rear and I just did not hear the rep right?
Does anyone run a knobbier tire in the front of their bike that is just a bit narrower than the rear? Will the contact patch be smaller? The same?
