1 - 4 of 4 Posts
Stem Fsa Carbon Os 99
Cranks Shimano Xtr
Shift Sram Xo
Rear Derealliers Sram Xo
Whells Notubes, Dt Swiss 240 Front, Hadley Rear, Spokes Revolution
Pedal Crank 4 Ti
Handelbar Fsa Carbon
Cable Nokon
Brake Formula Oro Puro 180 Mm
Seatpost Thomson Masterpiece
Saddle Selle Italia Xc 180 Gr.
Fork Fox F 100 2009
Rear Shox Rp23 2008
Nevegal 1.95 Whit Stan`s
Front Derealliers Shimano Xtr
Chain Shimano Xtr
Total Weight 10900 Gr- 24 Lbs
dream bike- can I have it's hand(-lebar) in marriage??? I'm assuming you race in some harsh terrain, where do you race? Your part spec is crazy awesome, probably worth more than my entire bike! How 'bout the frame- is the ICT rear suspension as efficient as they say, how about frame strength during out of the saddle efforts? Can ya give us a frame weight?
Kick some hardtail out there!
-S
Discussion Starter · #4 ·
Work 4.0 with Fox F120
Hello I`m from venezuela, the frame weight is 2392 gr (5,37 lbs). yes is so hard and nice to drive, the rear triangle is in aluminium (made by ellsworth), is very important to put the rear shox fox RP23 (The fox R is so bad), now I update the fork, i use fox F120, and is much better than F100, the geometry change a little but the new performance is amazing, i`m not race, i use in every place, i use it sometime in light down hill, (No jump, of couse) and the frame strenght, you dond feel anything is so strong. (i have , a ellswort epyfany too and is so similar the feeling when riding, (the ICT is not the difference) the difference is you multiple use that you make it.... (excuse me my bad english)
Bye, Bye.
1 - 4 of 4 Posts
