1 - 20 of 20 Posts
Does any one have recommendations to 29ers that have 110mm - 130mm of rear travel, slack HTsteep ST angles and long reach?
I know the Yeti SB130, Transition Smuggler an GG Pistol Trail are some options. Any others?
Super Moderator
Trek Fuel EX. Mino link in low sets headtube at about 66 degrees. Not the most slack but for a trail bike with 130/130 I find it works well.
Bumping travel at the front to 140mm would slacken out the headtube by ~0.5 degrees.
Rocky mountain instinct if you're willing to go 140-140. It's reasonably light (maybe lighter than some of the ones on your list?) and has ride 9 so is adjustable. It's slacker than the fuel, not as slack as the SB130
Knolly Fugitive is incredible. The new Forbidden Bike Company Druid is getting good reviews as well.
Sent from my SM-G935S using Tapatalk
fuel EX in low setting is 67 deg, not 66.
Officially, yes. Unofficially, no.
Mine with a 140mm F34 was 66d. With a 150mm fork it was sub 66. Most have measured their bikes to be considerably slacker, and lower than advertised.
That aside, the issue is the mega slack actual seat tube angle. If you are tall, the effective STA is not great. The bike (well, the light, high end one) just about gets away with it, because it's mega light, but it's not great.
downcountry bikes
Try out the salsa spearfish. with 120/100 front back. its modern and perfect for long endurance rides. salsa also makes great gravel bikes!:cool:
If you consider 480mm a long enough reach I've been enjoying the stumpy evo. It's 140mm rear travel but pedals and climbs surprisingly well.
64 degree HA in high mode. Mondraker may have something of interest as well.
I have been shopping for something similar, and recently ended up going with the Whyte S-120C RS. Thought hard and/or looked at the GG Trail Pistol, Giant Trance, Fuel Ex, Scott Spark, and Transition Smuggler. I only have 1 ride in on the Whyte, but feeling good about my choice for what I was looking for and what I got for the $. If cost and delivery time weren't a factor, I think I'd have gone with a GG Trail Pistol, as I like the ability to specify my parts and their american made/new tech story.
Nurse Ben
There's a huge amount of variation between these bikes; it's literally the largest and most popular genre, so you need to do some riding and decide yourself cuz asking on MTBR you will find lovers and haters for each and every bike suggested.
Fortunately, if you're not too picky, there are few bad choices.
Not sure of whether Spot Mayhem’s numbers are what you are looking for but I can speak directly to the fact that they Mayhem is an awesome mid travel(130 mm rear travel) 29er. I have the 5-star build and it’s amazing. If I am climbing, the living link suspension gives me a little extra support and push. If I am pushing through the infamous Northeast rock gardens, it is agile and excels in the chunk, and if I am ramming down a hill, it gives confidence. Just my two cents and I wish you the best in your search.
Not sure how tall the OP is but, some of these bikes won't work if you don't have long legs. For instance the Spot has short reach combined with long seat tubes.
A Fugitive in large has a 457mm ST, 477mm reach and 617mm stack.
A Mayhem has 483mm ST, 447mm reach and 622mm stack.
I could not possible fit on a Mayhem, maybe the OP can. Modern geometry is generally long reach, steep STA, slack HTA, and a lowish BB.
Just because a model is new does not mean it has "modern geometry". I don't think modern is the best term because, while the Spot may not have the numbers to make it "modern", it is certainly a well executed bike.
I'm just going off the bikes in the OP's post. Yeti SB130, Transition Smuggler an GG Pistol Trail. Fugitive, Druid, Offering and Whyte S-120 are in the parameters as well. Probably not a bad choice in this group.
NedwannaB
Good call on the Ws120. At least one advanced rider I know is very impressed by them and switching from the s150.
I was considering many of these bikes. Narrowed it down to the Smuggler and Sentinel because I wanted long and slack and a bike I can take to the park 10 times a year or so. I demoed the Sentinel on trails with tight technical switchback climbs as well as small root and rock jumps as I was worried about it sticking to the ground, soaking up all the fun stuff and being difficult to move around. It wasn’t at all. Climbed with ease and was very fun on the little jumps. So I bought it. And it is obviously amazing on the real steep stuff and bigger jump lines.
My thinking was - why I would get the Smuggler if the Sentinel climbs fine and was super fun on the smaller features on my typical trails. Full disclosure, I have always ridden less efficient bikes that favor the descent. Banshee Scream and Scratch, Santa Cruz Heckler and Butcher, Norco Range etc. So to me, every new bike I get climbs and pedals better than the last. If you have always favored bikes that climb well, you may want to go Smuggler as it will surely blow you away down hill. None of bikes listed here will disappoint. I recently rented a 5010 while out of town and while it wasn’t what I would buy it was plenty fun.
As mentioned earlier, there are too many options. Ideally you'd want to get out and demo some options, then do some additional research.
Now, I didn't do much demo but I did a boatload of research. But I was also looking for something not off the shelf, I wanted to build it. In the end, I built a bike that is identical (except for a few small parts and color way) to the top of the line spec and saved about $750ish. But I also took some parts off an old bike.
I'd mainly looking at direct to consumer options (YT, Canyon, Whyte, Commencal, GG, etc.) because I wanted to support the smaller guys that are doing something different and can make the cost lower. And of these options the frame only, or a la carte options are limited.
Long stupid story short, I went with the Commencal Meta TR 29, it climbs well it descends like its running from lava. But, any of the bikes mentioned in this thread will check the boxes you're looking for. Start with what you want to spend, then frame material, and then research options with those criteria, every manufacture is making a 100-130 bike with modern geo.
1 - 20 of 20 Posts
