1 - 4 of 4 Posts
Freshly Fujified
Not hard at all
Markleo said:
How difficult is it to instal just a front mechanical disc brake (deore), what are the items I will need to order and what tools will I need? Thanks.
You will need to order the complete brake set (caliper, rotor and torx screws). You will need a torx wrench for installing the rotors to the hub, as well as the right size allen wrenches for installing the caliper itself, as well as adjusting the pads.
Bob
pronounced may-duh
Don't forget something to cut the cable and housing. Posibly zipties to secure the housing to the fork. Ferells for the ends of the housing and a crimp for the cut end of the cable. But all in all it's not a hard install. Hardest part will be getting the caliper centered on the rotor depending on what style mount you have there are tiny shims for this. The shim take some trial and error but once done the adjustment should be good for a long time.
1 - 4 of 4 Posts
