Measuring travel on legs
938 Views 8 Replies 7 Participants Last post by  Uncle Six Pack
What are those things I see in pictures on the uppers to 'measure' the travel.
They look like hair elastics.
I liked to use a standard zip tie but I feel like dirt gets stuck under and around it only scratching the uppers.
1 - 9 of 9 Posts
Looks like o-ring to me.
If you use zip tie, don't cinch it tight. It should only be cinched tight enough so that it doesn't fall down on its own.
Its just an o-ring, can only be installed if you take the lowers off...
Zip ties don't need to be cinched tight...also the o-ring/zip tie does not move often enough to cause scratching stanchion.
Slide the zip-tie all the way to the top of the stanchions. It will only scratch them if you continually slide it back and forth. On my bike, when I slide it (gently) up to the crown, it stays put.
I thought it might be an o-ring,
I suppose next rebuild I will slide one on when the lowers are off.
Maybe a piece of twine would work...
If you're setting up sag on a new fork without an O-ring already installed, try throwing some baby powder on the stanchions to measure sag... Alternatively, you can also spray some light oil like wd40 on the stanchions to see how much sag you have.
dry erase marker
cjn1014 said:
dry erase marker
Trail dust works too :thumbsup:
Dude, if you wanna go the ghetto route (no offense, I've been guilty myself) then cut a rubber band and tie it on snug... when you are done, just rip it off...
1 - 9 of 9 Posts
