measuring a fork
704 Views 2 Replies 2 Participants Last post by  akdeluxe
Is there a trick/accurate way to measure rake using common tools? Besides the internet. Thanks!
akdeluxe
1 - 3 of 3 Posts
Yes.
You'll need:
-Flat surface. Granite countertop would be good enough. Concrete floor probably not.
-Flat object at least ~5mm thick and a minimum of about 100mm long. The longer the better, and the flatter the better.
-Ruler.
You'll want to lay the fork down so that the steerer is resting on your flat thing, which is sitting on your flat surface (you need to do this to keep the crown race out of the picture). Get the dropouts sitting the same distance off the surface, then measure to the center of the dropouts, and the center of the steerer. Subtract. This is your rake number. If you do a careful job, you should be able to get within 1mm or so pretty easily.
There are other ways to do it as well, but I'd say that's the easiest without having any fancy tools.
-Walt
Thanks Walt
Gonna try it. Thank you for your help.
I have a friend up here who has a WW bike.A 29er with room for SnoCats. He loves it. I have seen it. Pretty nice!
akdeluxe
1 - 3 of 3 Posts
