The Minewt and Magicshine battery packs are the same voltage (7.4V). But the magicshine has the regulator in the light head and the minewt has the regulator built into the battery pack. So by plugging the magicshine battery into the minewt head you connected the LED directly to 7.4 volts without a regulator. That fried the LED in the minewt head instantly. Replacing the LED, as Homebrew suggested, will fix the problem and increase the light output slightly.LWright said:Just messed up the light by plugging it into a magicshine battery. being stupid, I assumed the minewt used four AAA and the magicshine four AA = same voltage.
Upgrading sounds great, will check out the diy.
It's really not that bad and you don't need anything beyond a normal soldering iron. The P4 just has 2 leads and the center heat sink on the LED isn't soldered, so they're quite easy to remove and install. Being only 2 leads, you can heat one lead at a time and the led will tilt up to disconnect the first lead. Then you heat the second lead to remove it from the board. You may need a little bit of heat sink compound, but you can get that at Radio Shack or a computer store that sells components like CPUs.LWright said:Thanks, just ordered a SSC P4 U bin LED
Any hints on the solder job? I can solder 16 ga wire just fine, but circuit boards, not so sure about. need heat sinks?
