1 - 5 of 5 Posts
· Registered
Your question is too vague. What kind of conditions are you planning on using it in? Is it going to be a race only tire?
As with any tire, it probably works well for its intended purpose, but performance suffers when you use it in conditions it wasn't meant for.
· Registered
Discussion Starter · #3 ·
I undestand you massage, but I need confront the trails have more than one conditions. so I would like to know the performance of MaxxLite in:
1) hard and dry surfaces
2) Wet / mud conditions
3) Loose conditions
4) cornering control performance
· Registered
I've not ridden the maxxlites, but based on what I've seen of the tire the only one on your list that it will really do well on is hard/dry surfaces. Its tread pattern doesn't make for good mud or cornering performance. Loose conditions? It might work ok, but not great.
I think the only time you'd use the maxxlites would be on a hardpacked race course.
1 - 5 of 5 Posts
