You have to love the inconsistency in manufactures in sizing, even within the same manufacture and same model tire. I have been running 27.5 x. 2.8 Rekons on my my hardtail (really much smaller) and am building a new 29” hardtail. After talking to Mikesee who measures his 29 x 2.8 Rekons at 71 mm on a 40mm internal width rim, I went with the 2.6 and a good thing I did due to limited crown clearance. So how do they actually measure up? (All tires measured at 20psi, 2.8s have been mounted for 6 months, 2.6s about 20 hours, stretched at 40 psi).
I have no idea what the knob sizes are on the 2.4, but if similarly scaled, this could explain why people have such wide ranging opinions about the Rekon. In the 2.8 I have found them to be a great XC/light trail front and rear tire, with good rolling resistance and consistent good grip (conditions are hard, to loose over hard, to crumbling clay).
- Rekon 27.5 x 2.8 on 34mm internal width rim- Casing 66.4mm (this is both 60 and 120 tpi casings), knobs 67mm
- Rekon 29 x 2.6 on 35mm internal width rim- Casing 66.1 mm, knobs 64.4 mm..
