I've got about 250 miles on a set on my SS and they seem to be doing fine.aosty said:Anyone else think Maxxis Ignitors wear out a bit fast (particularly on the rear) ?
I can tell a big difference in wear on the rear vs wear on the front after a few weeks of pretty long riding. the middle knobs are noticeably more worn from grinding up long steep hills.aosty said:Anyone else think Maxxis Ignitors wear out a bit fast (particularly on the rear) ?
Same deal here... the wear isn't huge but the center knobs are pretty flattened... lots of traction loss on the steeps.Spookykinkajou said:I can tell a big difference in wear on the rear vs wear on the front after a few weeks of pretty long riding. the middle knobs are noticeably more worn from grinding up long steep hills.
Have you ridden the nano? Does it roll faster? I ask because I'm doing the kokopelli race next week and am debating switching to the nano from f/r ignitors.Padre said:I've got about 150 miles on mine on the rear, maybe more. Yes, it's wearing faster than a motoraptor, but that's ok since it's a way better tire than the moto. The rubber is softer!
I've not lost any traction though...hey Al, have you tried lessening the psi?
Normally running my rears at about 35-38psi..i found the Ignitior to SUCK at that pressure....I've settled nicely around 30-32psi and it's quite dreamy up and down now.
I'm sure someone of your "stature" could rock that tire at 25psi or less.
Last night, Leslie rode her rigid Rig around Aliso with the rear Ignitor at 25psi and the front Exi at 22. She had a blast!
Ouch... good luck.. try and post some pics.. we need more riding pics on this board. Sorry if way off topic.Spookykinkajou said:a desperate attempt to prepare for the 142mi race next week![]()
Thanks, and I'm about 100% sure I won't be bringing my camera along for the ride since I'm doing all I can to reduce weight(it's totally unsupported so we have to bring water pump and all of our food, etc.) Plus I doubt I'll be in a picture taking mood most the ridebigwheelboy_490 said:Ouch... good luck.. try and post some pics.. we need more riding pics on this board. Sorry if way off topic.
Spookykinkajou said:Have you ridden the nano? Does it roll faster? I ask because I'm doing the kokopelli race next week and am debating switching to the nano from f/r ignitors.
FWIW, for those that ride on rocky trails I would NOT recommend running the pressures he mentions. I ran 30psi at first and flatted numerous times. That psi was on very rocky trails and sometimes at very high speeds as well. I jacked mine up to 40psi and haven't flatted since but the traction is not so great up front and tolerable in the rear. I feel i could probably drop a few out of the front but haven't been tried yet since i've been mostly ss'ing it on the roadbike in a desperate attempt to prepare for the 142mi race next week
I'm 170lb, btw.
Hmmmmm....kinky...that low, eh? Cool...I'll drop her psi even more then.... sweet!aosty said:Thanks but I ain't that light... 170-175. I also like it waaaay more than the Moto - but yea, they like to be run way low... front 18-24psi, rear 23-26psi. Okay, the 18psi last night wasn't intentional but it worked fine.
Rig? Training bike? Did Niner take their bike back?Padre said:...Last night, Leslie rode her rigid Rig around Aliso with the rear Ignitor at 25psi and the front Exi at 22. She had a blast!
You never said which you thought was faster?Padre said:Hmmmmm....kinky...that low, eh? Cool...I'll drop her psi even more then.... sweet!
You may be right.OneGearGuy said:softer, stickier rubber will wear quicker. it's the usual trade-off, and i'll go for the grippier performance over longer life. but, as Padre mentioned, traction shouldn't suffer too much with moderate wear, esp at proper tire pressures. the rubber compound and casing design of the tire has more to do with straight ahead grip in many conditions than does the knob height.
Spooky- something just came to mind after reading this post and your rigid fork SPAM post; if you are selling your rigid fork because it beat you up, and you were flatting Ignitors when running under 40 PSI, it could mean that you need to pick your lines more carefully. bash less- float more. ride light, as they say. if Padre can run an Ignitor at under 40 PSI as 235# or more, your 170 should be able to do it in a snap!of course, this seems like stating the obvious, but... it seemed really obvious.
OGG
Padre will accept your challenge... top of Telonics... 5:30am on Friday.Spookykinkajou said:I pick my lines as best as I can but I probably go faster than the average bear does on a full rigid set up. To be honest and I hope i dont sound cocky but... thus far I've never ridden with anyone that goes faster on any bike down hills.
I have been nursing a sore left shoulder off and on for almost 9 years since a SUV hit me while commuting in '96. I hope my rigid setup will do okay for my riding- I may not be the DH rider you are.Spookykinkajou said:You may be right.
The rigid fork was not the primary cause of my shoulder issue. It's an old problem from many years of tennis that got inflamed after i did something to it while doing incline bench a few weeks before Pisgah and then I hit it again going down pilot rock to make matters worse. Basically, if I keep riding a rigid fork it'll never heal.
I pick my lines as best as I can but I probably go faster than the average bear does on a full rigid set up. To be honest and I hope i dont sound cocky but... thus far I've never ridden with anyone that goes faster on any bike down hills. I definitely took a serious beating going down pilot rock, for example. hell I even got a blood blister from the massive amount of heat built up on my palmsAll my flats were super slow leaks too that I discovered the next morning.
That said, my new idea for a new bike (ho ho ho) is a do everything cross bike. I've discovered I like road riding a lot too - the big centuries and more - but can't really justify dumping another 3g's in to a bike so i'm thinking a geared cross bike full timeHmmmmmmm
I
lol...aosty said:Padre will accept your challenge... top of Telonics... 5:30am on Friday.
I'm definitely a bike whore. Constantly changing mostly because it's fun. I really like the 29er and see no reason to change to anything besides it for trail duty. I really wish I had opted for gears too on the spicer. stupid stupid. SS'ing on the road is OK I just can't keep up on the flats and downhills with a max speed before spinning out of around 23mph. I currently ride a ~1985 scwhinn traveler on the road with a 48-18 setup, a front wheel missing two spokes, a really really bad seatpost(old bolt-on that doesnt sit straight), handle bar(too narrow), and stem(flexy) The frame feels dead compared to the Merlin my buddy let me ride a few times. flexy and slow accelerating.OneGearGuy said:I have been nursing a sore left shoulder off and on for almost 9 years since a SUV hit me while commuting in '96. I hope my rigid setup will do okay for my riding- I may not be the DH rider you are.
I understand where you are coming from with squishy forks. Sometimes they seem like the only (if not evil) alternative to not killing our bodies. Your idea for a do-it-all cross bike is exactly what I had in mind for my next bike. Geez, are we bike whores, or what?! You just got your Spicer a couple months ago and my Waltworks isn't even here for a couple more days, lol.![]()
But a crosser set up to do it all - maybe I will call mine the "Cross Dresser" - is the only real bike missing from my stable at this time (well, of bikes that I currently lust after).
Oh, I will prolly try the Ignitor at some point; on the bike, me thinks.
OGG
So you're going to get a Sycip?OneGearGuy said:But a crosser set up to do it all - maybe I will call mine the "Cross Dresser" - is the only real bike missing from my stable at this time (well, of bikes that I currently lust after).
