maximum pressure for a rock shox
2659 Views 3 Replies 3 Participants Last post by  LyNx
recon 120 mm? it says for 225+ lbs rider it should be 175 psi+
whats the maximum psi it cna hold before voideing the warranty?
1 - 4 of 4 Posts
hmmm
Curious why you ask? Don't know about the Recon, but I know the Reba is 250 PSI AFAIR - can't see why you'd need that much pressure at your weight. On my Reba's I used to run max 120-130 PSI when I was fully geared and weighing about 190-200lbs. If you're needing to go higher than 200 PSI at your weight I might look into either the shock pump you're using is not working right, or something is wrong with the fork.
1 - 4 of 4 Posts
