Well in fact I remember reading all that boring stuff before I assemble everything.
And I remember reading this in the thermal guide:
"At power levels with driver heat losses in the 2W range, it is sufficient to utilize a single heatsink attached to the gold thermal attachment area. As heat losses increase beyond 2W it may be necessary to provide heatsinking of the inductor to prevent shutdown and possible damage of the switcher IC. "
After reading everything and this conclusion you make it sound like losses higher than 2W are the worst case scenario, and you make it sound like IC heatsinking is just optional. As a newbie I just skipped that heatsinking and made a very good thermal path for the golden rectangle thinking it was enough.
Indeed the driver works well at sub-maximum levels but at max it shuts down in a couple of minutes.
You don't have any information about the IC failure temperature, that could be important info for the light designs.
Anyway I'll try to get a way to heatsink the IC with everything assembled
Good work with the programming.
