I have a 180 for mine and works fine.Bobbysix said:What is the biggest rotor you can run on the rear of a 575? Is it worth upgrading from a 160mm rotor? Or will I end up pulling too many skids with the rear wheel?
im running 180 fr+rr with much better results than with 160s. the 160s did not give me enough stopping power, got heluva reheated. hope mono minis btw. when i do change change itll be m4s.Yetifan said:I'm sure I asked Yeti this question ages ago, will check my inbox.
I think the reply was, the 575 can take a 8" rotor, but they would reccomend the smaller size, as you don't really need such a large size out back.
Andrew
i actulaly swaped the one on the pic for the remote control version... an upgrade absolutely worth every penny.[email protected] said:the Enduro Pro kit comes with 180mm Avids.
180 will give you more power and mor importantly cooling. It is a nice blend of size/weight/stress on frame/ground clearance.
jaco- Nice seatpost! I can't believe i don't see more!
