1 - 2 of 2 Posts
You wont blow the seals on a Marz fork, they are held in place with a snapring and designed to take high presures (Marz uses air volume copression to prevent bottom out on most of thier forks)..
So you dont mention if the fork is a coil with air assist, or an actual air fork....
If it is a coil w/assist, then just a few psi will make a big difference. @ 190 lbs I ran a few 'pumps' from a shock pump..could not even read the psi.
For an air spring, hop on and start airing up....stop when the frok sits at about 25 - 20% sag in 'riding position'. Adjust as needed durring first few rides.
Done...
1 - 2 of 2 Posts
