1 - 10 of 10 Posts
· Registered
Hey anybody know anything about the mavrick sc32 29er folk? Maybe like how much travel as a 29er it has I know all about the 26 version but I imagine some travel is lost going to 29 inch wheels. Also any track record on maintnance?
· Registered
You had better read up on them cause I was considering one on Ebay this past weekend and I believe you need some special Maverick hardware for the hub... all I remember is once I saw that I moved on.. I think some of them have trough axles and you need a special hub..
· 'Calm Down'
· Bikeoholic
I've got a SC32...
I am currently using a SC32 on my 29er and I like it for the most part. It is an excellently preforming fork with nice features. Now then on to the downsides... Proprietary 24mm front hub... this means no dice for a regular QR front wheel... or even a 20mm thru axle... Mind you I like the hub and its performance... but if you break the wheel, you probably won't have a back up anywhere near...
thats what I've got...
· Premium Member
The OP said "...I know all about the 26 version..." so that is no surprise.
· Registered
One more...
Nater said:
They all have a 24mm through axle and need to use a 24mm through axle hub. So far, I think there is the Maverick hub, along with Chris King and Industry 9 hubs that will work.
The Hope Pro2 hub can be converted between Maverick 24mm TA, 20mm TA, and QR axels.
1 - 10 of 10 Posts
