DT has a Eclipse kit to convert their rim for use with UST tires. They do not recommend using it to run standard tires tubeless. I asked about it at Sea Otter.. ("Tell me about your tubeless kit.")Gregzilla said:Oh yeah, do they both work fine with Stan's No-Tubes? I've read that certain rims don't work as well as others.
Greg
I ran some UST Fast Fred's ...lol - Imagine that.shiggy said:They do not recommend using it to run standard tires tubeless. I asked about it at Sea Otter.. ("Tell me about your tubeless kit.").
Hey Shiggy or Fast Freddy,shiggy said:DT has a Eclipse kit to convert their rim for use with UST tires. They do not recommend using it to run standard tires tubeless. I asked about it at Sea Otter.. ("Tell me about your tubeless kit.")
Do a search for my opinion on DIY tubeless.
DT Swiss has a rimstrip kit, made by Eclipse and designed specifically to fit their rims.FoShizzle said:Hey Shiggy or Fast Freddy,
So does the DT Swiss conversion kit enable to the rims to work with UST tires? If so, I did not know that and is the Eclipse kit mentioned above the same thing as the DT Swiss conversion kit or are there actually 2 different kinds??? Sorry for the dumb question.
thanksshiggy said:DT Swiss has a rimstrip kit, made by Eclipse and designed specifically to fit their rims.
It converts the rim for use with UST tubeless tires. It comes with a sealant but I do not think it is needed for the tires to seal on the rim (puncture sealer). It is not recommended for converting standard tires to tubeless.
Eclipse makes other kits for DIY tubeless.
