davep said:
Your set up will be great. There is NO problems using stans sealant at all. The sealant does NOT degrade tire rubber in any way at all. I run stans with all kinds of tires (maxxis, Mich, Kenda) without any problems at all. Sometimes getting tubeless to seat can be a little difficult unless you have a compressor. I sometimes use a C02 inflator to get the bead to seat..then add Stand and inflate to the propper PSI.
Tim, you are making lots of incorrect assumptions, and spreading these as fact..they are not! The warning on the Stans site is in reference (if you read it) to using poorly reinforced non-ust tires in a tubeless application. Lightweight non tubeless tires are not designed to take the same type of bead tension and forces that a tubeless set-up can apply. This has NOTHING to do with sealant (stans or otherwise) it is a function of the tire construction. Many of the problems were seen with Kenda single ply tires, it is no surprise that these tires have some of the thinnest and weakest sidewalls on MTB tires today. Kenda DH tires work tubeless without any problems...infact just about (all that I have tried) any reinforced DH tire will work tubeless perfectly. Many people prefer to use some Stans sealant as it will seal small cuts, seal any imperfections in the tire casing, and it will semi-glue the bead to the rim..helping to prevent any burping that can be caused by very low DH pressures.
Search here and the DH board on Ridemonkey for Mikeb. He works for stans and has posted LOTS of info that will help you have a better understanding of the truth vs fiction surrounding stans products...
No assumptions made. The tires were WIRE BEADED, DH tires. The only thing that can be ASSUMED is that there have been enough cases of Kenda's tires beads blowing out. The following is from Kenda's web site, also Schwalb tires have precautions.
DO NOT USE any fluuid based sealant product in your KENDA tires
Dear Kenda Valued Customer,
KENDA WILL NOT AND DOES NOT ENDORSE THE USE OF ANY FLUID BASED SEALANT PRODUCTS IN KENDA TUBE TYPE OR TUBELESS TYPE TIRES. USE OF ANY FLUID BASED PRODUCT IN KENDA TIRES WILL VOID ANY WARRANTY CLAIMS.
THANK YOU!
Kenda Management
If you have any questions, please contact us at:
Tel: (614) 866-9803 x1
Fax: (614) 866-9805
Toll Free: (866) 536-3287 x1
[email protected]
Also Schwalbe tires:
https://www.mtbtires.com/tech/sealant_test/pics_seal/schwalbe_disclaimer.gif
I don't have anything against Stan's, I think it works great, and like I mentioned earlier have used it for years now (since they 1st came to market). Most tires hold up well, but on occasion I have had a few blow out their side walls Kenda's, and Continental. I've only run Maxxis withe tubes, because my LBS advised me to avoid Stan's, because they have had problems in the past with sidewall failures as well.
Will I continue to use Stan's? Definately yes.
Will I use it in a tire that I paid a butt-load of money on (Maxxis UST)? Maybe, but I, would probually use it only for a race, or for a ride were the chances of flatting were good, and I would wash the tire out afterwards. At least until the thread started to wear down, at that point it wouldn't matter if it blew out, because it would need to be replaced soon anyway.
Here's a test done by mtbtiers .com. They tested how well Stan's actually seals, and it's effects of amonia degrading rubber. The result's were negative, but it doen't reflect that fact that it does happen...DAMMIT!!
https://www.mtbtires.com/tech/sealant_test/index.html
Also, Mikeb works for Stan's, of coarse he's not going to say any thing bad against their system.:ciappa:
