XCProphet said:
I am looking at my valve stems (I have 07/08s). Is this a common issue? Should there be a technical bulletin or recall?
Yes If you over pressure the rim, for example I have some 2.3 inch Nokian Studs, I rode last winter, the max inflationon the tire is 60 psi, but the rim can only take like 55 psi at 2.3 inch....
Buddy did the same thing...
Look closely at the valve hole, if there is a small whiteish line it is starting if not you are good to go.
Yes they have a tech bulletin that comes with the wheels.
