1 - 1 of 1 Posts
Hey there,
I've got some Crossmax29er wheels. I keep having to adjust the rear hub, because its always loosens up and gets side to side play in the hub.
Is there something I could use to tighten the hub adjustment seal nut, and keep its adjustment longer than a ride. It seems to me that this part keeps backing off and affecting the hub. I've adjusted the hub serveral time, I don't think lock tight would be good, because the tool to tighten the hub is only plasic and doesn't have a lot of contact. What about tread tape, I'm worried that debri will get into the bearings. Thanks for your input.
1 - 1 of 1 Posts
