You can run non-ust tires with a tube (a rim strip is recommended) or non-ust tires with Stan's Sealant on any UST rim. But why not just run UST?fr-rider said:I recently puchased Mavic EX 823's UST, the place where I bought them said I could also run thes wheels with tubes. Does anyone rides these and what do you think?
Actually, Mavic says not to use a rim strip when using tubes with UST rims.SCUBAPRO said:You can run non-ust tires with a tube (a rim strip is recommended) or non-ust tires with Stan's Sealant on any UST rim. But why not just run UST?
You're right, by the way where do you place the rimstrip. Is it the same as rim tape. I'm new to UST.shiggy©®™ said:Actually, Mavic says not to use a rim strip when using tubes with UST rims.
I know Mavic says its OK not to use rim strips but the area where they weld the rim together is ofter rough and may puncture your tube so a rim strip at this junction prevents that.fr-rider said:You're right, by the way where do you place the rimstrip. Is it the same as rim tape. I'm new to UST.
I see, thanks for the info.SCUBAPRO said:I know Mavic says its OK not to use rim strips but the area where they weld the rim together is ofter rough and may puncture your tube so a rim strip at this junction prevents that.
