1 - 2 of 2 Posts
Not too bad.
Pauly Junior said:
I haven't opened them up yet....
Is there anything I should know, or is it pretty straight ahead?
The rear hub has a bearing in the end of the freehub body,so this is going to have to be removed before you can get the freehub body off with the 10mm allen.You can also adjust the tension on the bearings like unsealed versions so don't overtighten the axle adjustment nuts,and have new bearings ready before you open them up if you think you need them.
1 - 2 of 2 Posts
