Mavic CrossMax SL Lefty
5682 Views 7 Replies 6 Participants Last post by  damion
Hi All,
i'm considering buying the Cannondale Prophet 4000. They come with the SL wheels.
I'm 230lb. I've been told that the wheels max rider weight is 220lb.
I ride agressive XC. I also didn't find the CrossMax XL in a lefty version.
Should i go for the Prophet 2000 that has the 819 wheels?
Thanks.
1 - 8 of 8 Posts
I didn't know the Crossmax SL had a rider weight limit... They are pretty strong so unless you jump and do drops, I think you should be fine.
The Crossmax SL is the only Mavic wheelset that fits the Lefty for now. The Crossland you see speced on the Prophet 1000 uses a Cannondale front hub (possible since it uses normal spokes unlike Mavic higher end wheesets).
Cross Max
I'm with Dan 100% on the Cross Max- I'm about 190lbs and have been riding crossmax on both my Scalpel and Prophet for last year or so and have had no problems-very strong and fast. If you are doing more heavy drops or jumps consider another wheelset. But for XC and moderate mountain I can enthusiasticaly reccomend the CrossMax. Good luck!
CrossMax
Thanks guys,
I do some drops while riding, such as in the attached picture.
Aifer said:
Thanks guys,
Nice pic! You only need to ask yourself, am I a smooth rider, or do I at 220 break stuff frequently? If the answer is that you are a smoothy=:) and you are on conventional, non freeride, non clydesdale type gear, you will love these wheels! Best of luck.
Aifer said:
Thanks guys,
I dare you to post that in the Downhill/Freeride forum to really get their panties in a bunch.
LOL, you're saying that because of the size of the drop or the lycra? Nice picture and the Crossmax SL should be able to handle that.
Are you a smooth rider?
Are you going to be keeping a close eye on the wheels, or are you a plug and forget type of person?
If that is the biggest of a "drop" that the wheels will see, and you are a smooth rider, go for it. You can always build a stronger wheelset for your days of DH, but I am sure that the SL's will work fine.
If you do nit like them, sell them as the race wheelset that they are, and build what you want around a Woodman Lefty hub and a bllack King ISO if that is something that interests you.
Are you planning on keeping the Jekyll? If so, you have a backup wheelset already, for the grimey says.
1 - 8 of 8 Posts
