UST tires would please even more people.TiRyder said:they will do a Crossmax type UST and a 20mm thru UST.
This should please a lot of people and lend even more credibility.
Do not expect details on the Mavic site until they are closer to shipping product.Davidcopperfield said:Hello
Which of those Mavic 622mm wheels are for 20mm throguh axle for disc brakes and with XTR or similar in excellence? I cannot find them on their website. Which one are the best wheelset for hard XC Trail and light AM/Enduro but not wider than 23 inner width- ideal for 2,1 inch tires. :???:
The only advantage they would have over I9 is the UST part, and there aren't even any UST tires available...Titus Maximus said:That's what I'm talkin' about! Mavic Crossmax 29'er UST goodness! Suddenly those I9 wheels are not pulling at my wallet quite as hard.
not any time soon.Davidcopperfield said:I am wondering when can we expect XTR 622mm/29" wheels?
You're out of your element here Cloxxki. I think this thread is for people who see a wheel as a wheel, not as an object made up of sub components, such as spokes, rim and a hub.Cloxxki said:Please do correct me as I'm sur I'm wrong.
Aren't Crossmax's just there for looks and prestige? I had 1997 Crossmaxes, and I haven't sen the concept change. Somewhat light and somewhat stiff wheels with so-so hubs at a premium. Wheels that can be beat by any LBS, just selecting proper hubs, 32 or 36 spokes and a nice rim, to end up lighter, cheaper and stiffer/stronger.
I would like the sealed rim of course, spoke tape does not like me, and that feeling is mutual.
If there is no advantage, what's the point? To look more trick? If they weight more, are less stiff, and cost more, why would somebody drop coin on them? So they can send them back to the LBS or the factory when a spoke breaks, taking your bike out of commission for weeks? No thanks. I like the I9 stuff, because it does have an advantage over traditional stuff, but I have yet to see this from Mavic.Quasi said:You're out of your element here Cloxxki. I think this thread is for people who see a wheel as a wheel, not as an object made up of sub components, such as spokes, rim and a hub.
Looks and prestige? I could care less. Lighter, maybe. Cheaper, probably. Stiffer/stronger, I don't think so (for a comparable weight). My Crossmax SL's are the best wheels I've ever owned. Light, stiff, strong. Zero problems. Have never even needed truing in a year and a half! And UST is the icing on the cake.Cloxxki said:Please do correct me as I'm sur I'm wrong.
I assume that if Mavic produces a UST type rim for 29er, they will provide a tire, or tires, as well. Others will follow. That's a good thing in my book. I've always used UST tires (with Stan's goop) with my UST rims, dispite the added weight. I just don't trust the tubeless "systems" as much. That said, I just ordered some ZTR Arch rims to replace my "not tubeless friendly" Delgado Discs. So soon I will be "Stanitized". We'll see how that goes. In the mean time, I look forward to 29er UST.Fulton said:The only advantage they would have over I9 is the UST part, and there aren't even any UST tires available...
go ahead and send jeff your money.
I don't often tend to be the naysayer, but there's only one company that I refuse to use their product... that's Mavic. However, it's a long story and that's just me.TiRyder said:Just got word that the first shipment will be arriving early Summer. Apparently, they will do a Crossmax type UST and a 20mm thru UST.
