Details, please!Ventanarama said:
Details, please!Ventanarama said:Got some of the new Maverick SC-32 forks in today. 1750g including the stanchion guards and with a 10" uncut steerer. Here's a few pics.....
Larry Mettler
http://www.mtnhighcyclery.com
Remains to be seen with this particular product.Jm. said:ugg..single crown inverted. Bad idea jeans...
There was a big advantage to designing the double crown DUC32 inverted, this dissapears with single crown inverted forks...dodjy said:Remains to be seen with this particular product.
Of course, we'll see won't we?
dd..''
Please elaborate.Jm. said:There was a big advantage to designing the double crown DUC32 inverted, this dissapears with single crown inverted forks...
This disadvantage you speak of remains to be seen with this particular product. Of course, AGAIN, we will see...Jm. said:There was a big advantage to designing the double crown DUC32 inverted, this dissapears with single crown inverted forks...
unsprung weight is a marginal benefit at best, because Mg fork lowers are extremely light, and a slight difference in the tire and wheel that you could could completely negate this "benefit.Nat said:Please elaborate.
You could have saved yourself alot of typing if you would have just said,Jm. said:unsprung weight is a marginal benefit at best, because Mg fork lowers are extremely light, and a slight difference in the tire and wheel that you could could completely negate this "benefit.
there is no more overlap to a single crown inverted as there is to a single crown-standard fork, this is a KEY issue and why a single crown inverted is so much different than a double crown inverted fork. The double crown inverted fork has MORE bushing overlap than a standard double crown fork, this is a very importance difference between inverted DCs vs inverted SCs...
There is huge lack of stiffness because the brake arch is missing, this would go "through the wheel" obviously on an inverted fork, so it has to be "left off", but it's key to resisting flex.
The only way an inverted fork can be "stiffer" is for-aft because it usually has bigger uppers than the stanchions, and it just happens that those uppers are usually bigger than most standard fork's stanchions. This is not an advantage though, because you can simply increase the stanchion size on a standard fork and completely negate this percieved benefit. Fox forks are a good example of this, especially the new 36mm freeride fork they are comming out with.
There is simply no good reason to make an inverted single crown fork. I have one and it is "ok" at best, great damping but there's just a huge difference in the stiffness and feel of my single crown shiver vrs my double crown shiver. They share the same name and some similer features, but the DC version is a difference like night and day in terms of stiffness and tracking. I don't doubt that maverick could build a better SC inverted fork than marzocchi if they put enough time and effort into it, but it's a lost cause because you still have to overcome the disadvantages, and in the end with the same amount of engineering and time, you could have made a standard fork that is just as light, and way stiffer, or make some other tradeoffs that would be worthwhile.
I believe that maverick has already "forgotten" about superior engineering and design and is just producing something that "looks" like their other fork, and they kind of don't really care whether they could make as good, or a better product as a single crown standard design.
Even with just a conventional single crown fork, you get three support locations--axle, arch, and crown. When you don't have an arch, there is a lot of distance to get leverage on that unsupported section of fork. Obviously the arch isn't the cure-all for all of the dynamics that engineers have to wrestle with on forks, but it definitely helps with some of them. I'm not aware of anyone who has built an inverted single crown that even rivals, much less surpasses, a high quality conventional single crown in rigidity. It's a mighty tall order any way you look at it. All of the inverted single crowns that I recall were very nice looking forks, and that seems to be one of their draws. They're unique and sexy, and I think that's why fork companies build them. Also there are lots of riders who will enjoy these forks and never really notice that flex.dodjy said:This disadvantage you speak of remains to be seen with this particular product. Of course, AGAIN, we will see...
d./
Considering some people have trouble with fox forks getting a tad close to the downtube, i think it is a fair comment.tscheezy said:Am I paranoid or does it look like the travel limiter/rebound adjuster knob is just waiting to slam into the underside of the downtube during the first wreck? What a strange crown design...
Hey thanks for the input. We'll see if Maverick has answered any of those issues.Jm. said:unsprung weight is a marginal benefit at best, because Mg fork lowers are extremely light, and a slight difference in the tire and wheel that you could could completely negate this "benefit.
