I know DT says it's fine and there are quite a few running the DUC but hows it performing on the Spot? How does it compare to whatever you were running before the DUC?
I've got the SC on mine and feel the a to c when sagged is a bit too low and even though I use 170mm cranks I've been getting a lot more pedal strikes than with any other 125/130mm fork I've used on the Spot. The performance is pretty good but from reports I've read the DUC is better again by some margin. I've also been offered a very good p/ex deal on a DUC. The other option I'm considering is a Pike air team, so TS if you've any more info or comparisons of the two fire away. Deano if your reading this how've you found the DUC compared to your TALAS in UK conditions?
Any help or comments appreciated
