1 - 7 of 7 Posts
local trails rider
Yes.
No problem at all.
I am currently running SRAM Power Links on HG-53 and CN-7701. HG-73 is no different.
I have been told that other (non-SRAM) "quick-links" are better for use on Shimano chains such as KMC, etc... I have used the SRAM link on Shimano chains with only one breakage problem.
ballbuster
9 speed works...
liquidsuspension said:
Can you use a masterlink, perhaps a SRAM powerlink, on a Shimano LX hg-73 chain, so I don't have to keep using replacement pins all the time?
8 speed does not. I run Powerlinks on my XTR chains and have never had an issue. I could not get the 8 speed stuff to work together, tho. Shimano's 8 speed chain inner plates are just a CH wider than SRAM. I couldn't get it to close.
Discussion Starter · #7 ·
Thanks for the heads up. I was considering a powerlink for my wifes 8 speed....nevermind
1 - 7 of 7 Posts
