my rear brake lever has been sticking (hayes nine). Brake work perfectly fine except the lever and caliper won't reset to its original position unless I 'push' the lever all the way out. I suspected the lever pivot might be the issue so I loosened it -- nothing. Then I took the lever pivot off completely and the cylinder compressed and decompresses on its own but when I reattach the lever it's almost as if the cyclinder sticks or doesn't have enough "oomph" to get it all the way out.
I'm new to hydros so i'm kinda pulling my hair out here...:madman: :madman: BTW, when I detach the lever pivot, the cyinder seems to swivel quite a bit. Is this normal?
At this reate it won't be long before I move to mechanicals...
