1 - 2 of 2 Posts
Does anybody know if and how you can reduce the travel on the above fork, Ive read somewhere that the 05 model can be reduced but cant find anything on the 03.
Was something like infllate to 200psi and and compress the fork which then increases the negative air chamber????
Its running at 120mm at the minute and I would like to reduce that down as its just not good on my Spider, the steering is just poor when climbing technical sections.
Cheers
JB
The problem with increasing the negative pressure to lower the fork is that the negative chamber on your fork wasn't designed to handle that kind of pressure and will most likely start to leak. You do not want to go above 150psi on the negative pressure. The only safe way to reduce the travel on that is to replace both cartridges... And that's not cheap...
Brian
1 - 2 of 2 Posts
