MK_ said:
... some time ago I upgraded from HSCV damped Z1 (04) to TST damped AM1 (05) and felt little in terms of damping improvement, aside from external compression adjustment. ... The whole bladder enclosure is very discouraging from me ever purchasing another fork with one as it complicates the oil change process by adding the bladder bleeding to the task.
_MK
_MK your posts have been hitting the ball out of the park lately.:thumbsup:
I went from a '03Z1FR1 to an AM1 (Z1am frankenfork) and really did not notice an improvement in damping apart from the adjustability. Some aspects I liked less as it was rather divy. The RC2 is a vast improvement for my tastes.
The other issue is the bladder style damping of the TST. While I think it's a interesting design (I read the descriptions) The bladder in the AM1 I have tends to require bleeding after a prolonged useage. Bleeding in itself is not terribly difficult but it is a nusance compared to simply dumping the oil out of the fork legs.
Bleeding the TST requires removing the cartridge, removing the cap. Draining it, filling it, priming it, squeezing all the air out of the bladder, closing the cartridge, pumping the cart, reopening it, topping it off and reclosing it....THEN you can finish rebuilding the rest of the fork.
The RC2 in my 66SL works in an open system so you don't need to do any of that.
IIRC, my understanding of how the bladder operates is greater compression force causes the bladder to strech and expand which exposes additonal ports on the inside of the damper that would otherwise have been covered by the bladder walls. The bladder strech is controlled by the amount of oil and pressure outside the damper in the fork legs. The problem with this is that over time, the repeated streching introduces air into the cartridge and that makes the damping notchy.
Oh yeah, and I think the process for bleeding my 2-pot XTR brakes is pretty darned simple.
