Hi Everybody,
Last week, I received and installed on my bike a '04 Marathon S 105mm that was too good to pass up from an online dealer.($300.00) Well, when I received the fork, I was so excited that I went straight to putting the fork on the bike. I did not check for oil levels or anything. I pumped up the air preload, checked sag, and went for a short ride. First thing I noticed is that this fork made the front end of my bike much lower than the RS Duke XC/U-turn it replaced set at around 100mm or so. After getting back home, I measured the distance of exposed stantion when fully extended which was only 110mm. Then I tried to bottom the fork without any preload, I was only able to get less than 75mm of travel. I bounced as hard as I can and I'm not a light-weight being close to 200lbs with gear.
So I decide that I'll ride it for awhile to see if I get more travel as the fork breaks in.
150km later, I check the length of exposed stantion and now its 112mm. And after the bounce travel test, I am now getting 85mm of travel on the dot. I still have not opened the fork to check oil levels but am starting to think that this is not a 105mm fork but the 85mm version.
Can anyone out there with the same fork confirm my suspicions? Or maybe I don't have the fork adjusted correctly.
Any comments, tips or advise will be greatly appreciated. TIA.
Nuts.
Nuts.
