Phil~M said:
Will the lowers from an '06 Dropoff Triple fit an '06 All Mountain 2? Thinking this would be a cheap and eay way to upgrade the AM to 20mm bolt through, as I already have both forks.
The All Mountain series was redesigned in the 06, whereas the Dropoff retained the Z1 chasis. The crown was changed as well as the lowers, increasing the overall axle to crown by 3.3mm.
Having said all that, it doesn't rule out that the lowers might fit, however, you should really call Marzocchi to verify. You'd do us a favor, as well, if you reported back.
Marzocchi's # is (661) 257 6630.
_MK
