1 - 4 of 4 Posts
Hi can anyone tell me what types of adjustment the marzocchi 55 sport on my ns core 2 have. I have just ordered it but the company dont say what it has. cheers ro55
five seconds on google
Description
From Marzocchi's ultimate all-around performance series of suspension forks - The 55 ATA Micro handles more than just all-mountain riding. This is your fork for uphills, downhills and even light freeride. Just point it and it will go. The 55 ATA Micro features air travel adjust from 125mm to 165mm via a dual air spring, and TST Micro technology for Lock Out, Micro Compression adjust, Compression and Rebound. Beefy 35mm nickel coated alloy tapered stanchions and a 20mm QR Torque Axle provide the needed stiffness for more demanding riding.
The ATA (Air Travel Adjust) has two air chambers that control the beginning and end stroke of the fork. You adjust the pressure of the positive air chamber and the negative chamber balances automatically. Air pressure values will vary depending on your riding preferences, terrain, and preferred travel positions. The lower air valve is the PAR (Progressive Air Resistance) chamber. PAR adjusts the progression of the spring rate and controls bottom-out. The PAR valve is on the lower part of the fork leg and is protected by a red protection cover. The rotation of the Silver-colored ATA knob on top of the fork leg, allows you to adjust the stroke and the height of the fork in an infinite number of positions within a range of 40 mm.
With TST Micro technology, you can adjust the fork's rebound via the black knob in the lower part of the fork leg. The red top knob allows you to adjust the fork's Micro Compression. The gold knob on the top of the fork leg sets the threshold of compression by adapting the suspension system to the type of terrain. Lockout is activated by turning the golden knob completely in the closed position, then shifting the red lever.
  • 125mm to 165mm Travel
  • TST Micro (Lock Out, Micro Adjust Compression, Compression, Rebound
  • ATA + PAR (40mm Air Travel Adj, Pos. and Neg. Air, Progressive Air Resistance)
  • Air Spring
  • Aluminum Steer Tube
  • 35mm Nickel Coated Alloy Tapered Stanchions
  • 6" Post Mount (Max Disc 8")
  • 20mm QR Torque Axle
  • 5.2 lbs
  • White
http://greenfishsports.com/product/363_388-suspension-forks/3968-marzocchi-mountain-bike-fork-marzocchi-bomber-55-ata-micro-2009.html
1 - 4 of 4 Posts
