1 - 11 of 11 Posts
Hi all, quick question for you. Can I interchange other brand steering tubes on my marzocchi z4 forks? My friend has an uncut 1 1/8 steer tube (above) but doesn't remember what brand it is although he doesn't think it's a marzocchi. It looks like it would work, appears very similar to what I have but I thought I would ask here to get some feedback. Lastly, the one I currently have is aluminum and this new one is steel if that matters. Any help is greatly appreciated. Thanks.
Discussion Starter · #3 ·
Hey, I was going to use a bench vice and a heavy hammer to make the swap, I hear all the professionals do it this way. Just kidding, my Z4 has pinch bolts on the crown. So, do you think it will work?
Takw/agranofsalt
Ladies Man said:
...my Z4 has pinch bolts on the crown....
Really? How old is it? Most modern forks use cryo fit for the steerer tubes. Can you post a picture?
I can't say for sure but it might work if the diameter and height of the clamping area is the same.
Good luck
mtbr "member"
The older Zokes had pinch bolts
I think the last year for pinch bolt crowns was 1998. In terms of the steerer, the fact that it's another manufacturer's doesn't matter as long as the size and measurements are the same. The lower "flange" that holds the steerer in the crown should fit as the original does. The portion that clamps to the crown should be the same diameter and height. And the taper that the lower headset race fits onto should be at the same level as the original once the steerer is installed (the race should sit snug and flush to the top of the crown.
REEK
Glad to Be Alive
dude don't do it.......man if that fails you are in a world of hurt...leave it to the pros on that or at least be filming everything you ride so I can have proof when I say "told you so"
I've used a steel RST steerer tube in a Marzocchi Z2 with a pinch bolt crown. As long as the OD of the steerer tube is correct for the crown, and the steerer was designed for the same purpose, I don't see a problem. Steel steerer were available from Marzocchi.
mtbr "member"
The only way the set up will fail
is if the lower "flange" is not big enough to stop the tube from pulling through crown. As you tighten your head set, you're basically placing the headset under compression while the two ends of the steerer are under tension (the lower "flange" and the upper star nut- top cap). Other than the tube pulling through due to improper sizing, you'd only have to worry about material failure such as the crown or steerer breaking. The former should be obvious if the fit is good or not. The latter, hard to predict in any situation.
REEK
Discussion Starter · #9 ·
Thanks all. I'm going to take my Z4 apart and do a measurement comparison to see just how "identicle" these steer tubes are. If they are exact I imagine I should be safe. I posted the same question in the suspension forum and was told that many steer tubes are interchangeable. Anyone else care to comment? Is it an accident waiting to happen or is this something that others have done with no problems? I don't want to have to ride a wheelie ALL the way home from the trails with missing front teeth.
p.s. that's a nice boat shot SMT also, I think you have more posts than anyone else on this site. You must be a MTB fiend :)
1 - 11 of 11 Posts
