Marzocchi Bomber MX Pro LO 2007
3349 Views 4 Replies 4 Participants Last post by  bad mechanic
Hi guys!
there are rumours about marzocchi quality recently.
but, refer to this thread title, i'm going to purchase that item , whicht I believe it was 2007 model and built in the same year or older. Year 2007 Marz is still reliable isn't it ?? This offer comes from Aussie for AUSD150.
Am i making a good purchase ?
1 - 5 of 5 Posts
Looks like it's an '08 model~
http://www.marzocchi.com/Template/detailSPAForksMTB.asp?IDFolder=208&LN=UK&Sito=usa%2Dmtb&IDAnno=55897&mCO=Prgho%5ChduPrgho%5Chdu%23GHVF%2F%23VhulhRuglqh%2F%23weoRjjhwwl1LGRjjhwwr&mCW=DQG%23%26Prgho%5ChduPrgho%5Chdu%26%23A%40%23%2A5334%2A%23DQG%23%26DP%26%23%40%234%23DQG%23%26Prgho%5Chdu%26%23%40%2388%3B%3C%3A&mCJ=&IDOggetto=56129
There's probably a reason why it's so cheap....
If you're getting it as a temporary fork to tide you over while looking for a new fork den by all means no problem....
Otherwise I would pass on it....
Hope that helps~
Mas :)
Oh hokae~ Oops.....
But I'll still stick to my statement of buying it if it's just for tiding you over until u get a better fork~
Be it an '07 or '08 model~
Cheers!
Mas :)
The MX Pro LO 2007 is a low end fork which uses damper rod for damping. So once the trail gets rough, the fork is going to start spiking, and you'll be in for a harsh ride. I would strongly suggest saving your money, and buying something which has a proper damping system.
1 - 5 of 5 Posts
