SOC14: 2015 Marzocchi Early Looks ? 650B Carbon Forks, Espresso Coatings, Enduro Shocks & More!
Introduced as their enduro oriented fork, the 350 CR offers a 35mm stanchion chassis that tips the scale at just 4.2 pounds. The 650b fork is offered in tapered steerer only with a hollow forged crown, and a new arch that is wider and flatter for improved stiffness from the lowers. The arch also tapers to a point on the front of the lowers to improve the lateral rigidity while a 15mm QR holds it together.
Inside the 350 CR uses an air spring with travel set at 160mm but internally adjustable to 140 or 150mm. Damping is controlled through Marzocchi's Dynamic Bleed cartridge which is a sealed damping system to ensure all the air can be removed from the oil before use. The CR offers adjustable compression and rebound, and the GRC coated stanchions. Retailing for $769, the fork will be available in the US in two weeks.
Aimed at the cross country market, the 320 LCR Carbon carves out a new lightweight option with the new stanchion and seals as the rest of the line up. To be offered in 27.5 and 29″ forks, the 320 will eventually be sold in LCR, CR, and R versions with a one piece carbon monocoque steerer/crown assembly and redesigned lowers. To shave as much weight as possible, the lowers are carved out any place they can without sacrificing stiffness. LCR forks will also have a new one piece seal system to reduce weight which is expected to be around 1450g for the 29er, and 1425g for the 27.5 fork. Price is TBD with an expected delivery in January.
