Hi folks
I'm hoping for some advice here. I've just completed an oil change on my 2006 66SLs - found it very easy - but something's not right now. I can only get a maximum of 125mm of travel from the forks, even after blowing the air out of all the chambers (2 x positive, negative, PAR) and compressing them unweighted. The fork just physically can't be compressed beyond 125mm of travel, so I'm missing a good 45mm of travel...
Does that sound like the oil level could be at fault? i.e. too much oil? I'm a bit of a beginner when it comes to fork servicing and technical knowledge of how they work, but I suspect the oil level is incorrect and excess oil is stopping the fork compressing - does that sound feasible? If it is too much oil, which leg is it likely to be: right (non-disc) or left (disc), or both?
I used 7.5wt oil and followed the guidelines in the Marzocchi service manual of 50ml in right leg (non-disc), and 200ml in the left leg (disc side). However, I've searched on mtb.com and found mentions of 40ml in the LEFT and 200ml in the RIGHT (http://forums.mtbr.com/showthread.php?t=160024). Is the Marzocchi service guide wrong, has the person on mtbr got it wrong, or does it sound like I've messed up? Either way, something ain't right!
Hoping someone can shed some light on this. Thanks, a11y.
