1 - 5 of 5 Posts
· Registered
I bought a Marzocchi 66 with 150 mm of travel thinking that the "travel change kit" would be similar to spacers I had on my DJ fork. After checking out a few bike shops, I was told that it was a matter of removing a spring from the bottom of the fork and moving it to the top. Does anybody know how to change the travel from 150 mm to 170 mm on a 2005 Marzocchi 66 VF? Tips and recommendations are welcome. Thanks.
· Registered
I'm not sure about the specifics of that fork, but I was looking for a similar travel change for my 2004 Marathon SL fork and found this on Marzocchi's site: http://marzocchi.com/spa/mtb/products/accessories2004.asp?LN=UK&Sito=usa-mtb&p=1
I would assume there is some similar info for the 2005 series. There is no kit for my fork, but they've gotten me started on a path to the goal. Now for the phone call to Marzocchi USA!
Cheers, Happy New Year!
· Registered
I'm pretty sure on the 06"66vf you can just remove the spacer from under the negitive spring and add spacer into the upper spring stack .
I'm not 100% sure on this though , as I have only lowered the travel in my 66vf , I never tried to extend it .
· Registered
Discussion Starter · #4 ·
I don't know whether it was right or not, but I did it!
My need for instant gratification got the better of me, and I found myself taking the entire fork apart yesterday. I did find a black plastic 20mm spacer under the negative spring and moved it to the spring stack. I put it on top of the spring, as was correct with my old dj fork, even though the bottom seemed a more appropriate position. I believe that the travel has increased and I did it correctly, but I would appreciate any feedback from those in the know. Thanks to all who contributed to this thread.
· Registered
From what I know about how the insides of the 66VF work this sounds correct to me .
As long as your not getting a harsh topout noise , you got it right !
if you havent already , you may want to add 10cc more oil per leg for the longer travel .
Bumping up to 10wt or 15wt wont hurt either , in the new 06" 66vf
I run 15wt in the compression side , 10wt in the rebound side .
Hope this helps !
1 - 5 of 5 Posts
