I'm a newbie and just purchased a Iron Horse 7point7 and have several questions on set-uping the Marzocchi 66 RC2X that came on it.
I'm 190lbs, ride in hardpack desert (SW Idaho) predominately. Want a plush but responsive ride. Speeds no faster than 20mph and drops 6' max.
1. What is the stock spring weight in the forks, and is it to light for my weight? If so, what spring should I go to?
2. How much sag should I be set-up for (recognize the springs will do this).
3. The forks have air valves on each leg, is this to set pre-load vs new spring or set set the ride characteristics?
4. How much, if any, air should I have in each leg (currently set at 0psi)?
Thanks in advance for your help:thumbsup:
