The famous ETA funktion is not an option on the 66 forks this year.
Do anyone know why, and if it will be back on the 66 in 2009?
Hello,Gunnar Westholm said:Weard! I just found a link to a 2008 66 RC2 ETA fork! But i cant find it in the lists on the site...
Even though they suck, fox has sold a ton of the talas 36 forks. Why? Because a 160mm fork that is not adjustable is way too limiting in terms of your riding, it sucks for going up hills, flat out, a 55 RC3 ETA is what would do the trick. The ETA on the bigger 66 models is also nice for those huge bikes and allowing them to do some of the big climbs.Marzocchi Tech Department said:Hello,
ETA will not be offered for 2009. Based on Product managers, aftermarket sales, and the powers that be they removed it from the line. Believe me we are already regreting the chioce and if I have anything to do with it it will make a resurgance. It again is going to take some time. It has to be my favorite feature too. I posted the other thread to see what kind of response it got and to show my bosses and the decision makers that people want it.
We are still listening though!![]()
I have a 180mm 66RC2X on my 6point. I had the 07' 66SL ATA. I never felt the need to change the travel so I went to the coil version. I have no problem climbing with it whatsoever and we have some heinous climbs here in CO. Granted the front end will want to lift on the steepest climbs here in CO but I can move forward for those or raise the seat a little.Jayem said:Even though they suck, fox has sold a ton of the talas 36 forks. Why? Because a 160mm fork that is not adjustable is way too limiting in terms of your riding, it sucks for going up hills, flat out, a 55 RC3 ETA is what would do the trick. The ETA on the bigger 66 models is also nice for those huge bikes and allowing them to do some of the big climbs.
Um, yeah, well for 99.9999% of people (every other rider), riding up a real steep climb with a 180mm fork is pretty darn impossible. You say you can just move forward or raise the seat, but I've found it pretty damn impossible to make it, and I have a lot of climbing power and ride all climbs in the middle ring mind you.wormvine said:I have a 180mm 66RC2X on my 6point. I had the 07' 66SL ATA. I never felt the need to change the travel so I went to the coil version. I have no problem climbing with it whatsoever and we have some heinous climbs here in CO. Granted the front end will want to lift on the steepest climbs here in CO but I can move forward for those or raise the seat a little.
The ETA cartridge is heavy and that is why I opted to choose the 66RC2X over the 66RC2 ETA. The ETA fork is heavier.
I am just saying it's not as impossible as some would indicate. Here in Vail, CO there is no choice but to climb. We are stuck in a tight valley. Rides of 2000' to 5000' vertical are very easy to plan but I stick in the 5-20 mile range. So I understand what steep is. I am about to do a ride on Sunday that is 2000' in 5 miles. But I digress...Jayem said:Um, yeah, well for 99.9999% of people (every other rider), riding up a real steep climb with a 180mm fork is pretty darn impossible. You say you can just move forward or raise the seat, but I've found it pretty damn impossible to make it, and I have a lot of climbing power and ride all climbs in the middle ring mind you.
Thats sounds really weard to me! :skep:wormvine said:>>>>>>>
Lowering my fork just makes my back bend more and it starts to hurt.
It just goes to show that everyone's perspective is different.
I
Well I am 36 and have beat up my body. So it could be other factors as well as body geometry.Gunnar Westholm said:Thats sounds really weard to me! :skep:
The reason to lower the front end, is to get the same body geometry / comfort on the climbs as on the flats.
Or seen from the other view: To be able to bring as much downhill geometry up the mountain, suffering as little as possible.
Thats why so many allmountain riders use Talas, 2-step Air, Launch Control and ETA equiped forks. And i think ETA are the only one on coil forks? (Did I forget any "easy adjust" system?)
Do you get back pain when pedaling hard on the flats to? When the geometry is the same as if you lower the fork on a steep climb..
Maybe you have the sadle to low, and/ or a to long and/ or low stem?
