Padre said:I know it weighs 5lbs.
But I'm needing a solid set up.
Any thoughts on it, good/bad?
No reviews for the niner version I could find.
Speak now, or forever hold your peace.[/QUO5TE]
5 lbs... I never knew the fork was that heavy. Mine came on a GF Paragon and is the 80mm version. I have nanoraptors with wire beads and stans. My bike is set up as a singlespeed and weighs 25 lbs complete. Not anywhere as light as my soulcraft singlespeed at 20 lbs.
I ride in So cal and ride rocky, dusty decents and long steep climbs. I really like the fork. I weigh 155 so, I'm no clydesdale, but I have ridden my share of flexy forks (sid, mars, etc) I have Fox's on my other bikes for comparison. The bump absorbsion is not as sophisticated as the Fox but it gets the job done. The big wheels makes you feel like you have an extra 1/2 inch of travel (but I'm sure you already know that). I run about 5 lbs of extra air pressure to keep the fork from bobbing while climbing. I know the fork has the ECC but I seem to forget to unlock it when going down hill. So I leave it open and have adjusted to the firmer feel. It takes a lot to bottom the fork but that is usually what saves my a** from crashing!
The steering seems solid, although I have noticed it is better to lean the bike over to turn rather than really turning the bars. Which would negate a lot of fork flex "feel". The fork will hold airpressue for a few months without needing a top up. The only grip is I wish Marzzochi would come up with a handlebar lock/unlock like the SID. Oh well nothings perfect.
OK....here goes. First some caveats:Soupboy said:...I want a real review on this fork...especially in the context of clydes.
Sean
Appendage said:I have the 2002 MXR Air that was stock equipment on the GF Tam at the time.... 2 years and thousands of miles and it never leaks any air or oil, and there's no slop in the bushings. Note: I only weigh 175 lbs....
Thanks for your input.pigpen said:<subliminal message on> Buy a BW 0.8. It's stiff and reliable. <subliminal message off>Hope that helps C
Padre, from reading your posts over the last months, year, whatever, it seems you have your mind made up about WB, and you don't like them, despite what the overwhelming evidence and opinion from others is on this board, including MC and other GDR racers might say.Padre said:My experience w/ WB has been less than reliable.
Is the extra $300 that I'd have to pay for the .8 worth it?
Do the O4 Mx Comp's have mechanical pre-load or air assist?
It's definately difficult considering spending $650 on a new WB when my experience was less than stellar. You've observed me whining, hemming, hawing, etc in order to help myself decide. Has WB worked out the issue of the the rotor almost touching the stanchion w/ the .8?ncj01 said:Padre, from reading your posts over the last months, year, whatever, it seems you have your mind made up about WB, and you don't like them, despite what the overwhelming evidence and opinion from others is on this board, including MC and other GDR racers might say.Marz are good forks, just buy one already....
Padre said:Thanks for your input.
I had some avid disc's on my .8, and while the rotor was close to the lowers (stanctions are the part of the fork that goes into the lowers), it never came close to touching, I don't think it's an issue to be corrected.Padre said:It's definately difficult considering spending $650 on a new WB when my experience was less than stellar. You've observed me whining, hemming, hawing, etc in order to help myself decide. Has WB worked out the issue of the the rotor almost touching the stanchion w/ the .8?
