The 55 TST2 comes stock @160mm while the 55 R is set at 140mm.enduroman said:Just wanted to know how you differentiate between a 140 mm and the 160 mm travel fork. You see somebody wanted to sell me the fork but claiming it to be 160mm model. thanks
P... Are you positive on the 55R being able to be extended??Mr.P said:The 55 TST2 comes stock @160mm while the 55 R is set at 140mm.
Both of the 55 TST2 and 55 R and be set at either 140mm or 160mm with a spacer change from positive spring to negative spring or the other way around.
P
It is true!! :thumbsup:Warp said:P... Are you positive on the 55R being able to be extended??
A friend of mine has the 55R at 140mm but wants a higher A2C for his Reign X.
Just remove snap ring on bottom of right stanchion, pull out push rod and remove spacer???Marzocchi Tech Department said:It is true!! :thumbsup:
And add the spacer to top of main spring between it and the air preload do-dad.Warp said:Just remove snap ring on bottom of right stanchion, pull out push rod and remove spacer???![]()
Roger that. :thumbsup:Mr.P said:And add the spacer to top of main spring between it and the air preload do-dad.
For better small bump compliance, cut same diameter PVC pipe (as the spacer) to half of spacer height to reduce spring preload.
P
