Has anyone else modded these lights? I've recently put together a light using an old style Marwi housing and clamp and a Cree LED. I have found that it's very very cheap and fairly simple to build. It also runs extremely cool, has a long battery life off of normal AA's, and has multifunctional settings.
The reason I chose this setup is, I used to have a Marwi dual halogen setup using the same light when they first came out, but the battery and bulbs died. I loved the Marwi lights when they were working, and I used to guide my riding buddies back to the trailhead when we get caught in the dark on dusk rides. I recently got the LED bug and have been weighing my options. I'm also on a shoe string budget and couldn't afford anything retail, other than a basic commuter light.
I got the idea after seeing the success El34 has had, but I wanted to make my own heatsink and optics, because I like designing stuff and wanted to see if I could pull it off, without any help from a machine shop. All I used were spare parts from around the shop, and simple tools like a hacksaw, files, grinder, etc.
My setup is:
Old style Marwi "bell" light, with matching old style handlebar mount.
Current regulator: DX-6190 5-Mode 1-amp board
LED: Cree XR-E Q5 star
Heatsink /adapter: Scratch made from copper pipe
Optics: lens from a low power LED flashlight, and reflector from a incandescent flashlight.
Battery: 3 NIMI AA cells, In a PVC pipe and flashlight springs and caps. Velcro strapped to the top tube.
I got the light from www.hoffmanamps.com and the electronics from www.Dealextreme.com Everything got to me in a week, so I'm pretty happy with both vendors.
Total price: $30
Build time: maybe 4-5 hours.
The challenges in this project were the adapter/heatsink and the optics.
The heatsink required me to cut a copper pipe in half and pond it flat, lapp it smooth and grind to the inner diameter of the light, to make the forward facing star mount.
Then I had to take a 3/4 " pipe and chop it to the right length, then make 3 cuts through it at 120 degree intervals. Then I broke off 2 of the flaps and bent the remaining 4 out slightly and took another pipe and fed it through the first and pounded it to till it had a flat surface
I then took the 2 parts and soldered them together with a torch, did some tweaking on the roundness of the rear flanges and drilled holes for the star screws and wires.
The optics were tough since the halogen bulb and lens are fused together and the total length, even if I cut the light out of the reflector it's too long for the heatsink. Instead, I grinded down a plastic lens, and took a plastic flashlight reflector and grinded it down as well.
Installing the electronics was easy once I figured out the wiring layout of the regulator. With everything mounted and wired up it works as well as my old 12W halogen, but with 5 modes and a very bright, long distance spot in 3W mode. I plan on adding a second beam, with flood optics and use a P7 or XP-G, but I don't need that kind of setup right now.
My setup is:
Total price: $30
