1 - 20 of 20 Posts
whodaphuck said:
Anyone try this? I know Marin only sells 'em with 100mm forks, but I was thinking of upgrading.....
hey there- as you know, i went the route of teh attack trail with the talas up front. officially 120ish miles in the last month - i promise a write-up very soon. worked on it the other night, but got called to bed...
Yes, that's fonetic
Discussion Starter #4
856er said:
How about getting a Marin Attack trail,
you get 4-6" travel front and rear (tara and quad link)
Fox Talas RLC 90-130mm fork,
this way you know the geometry will be correct for the extra travel,
bit extreme I know but the best of both worlds,I'm assuming here its available over there.
http://www.marin.co.uk/marin-2006/bikedetail.php?ModNo=3635&CMod=1
We didn't get the tweaks to the frame design that you guys over there in Whyte-land did :confused: . Seems Marin UK is an entity unto itself and they do as they please. Marin (here) won't incorporate the changes, i.e. the gussetting, and frame geometry, concentrating more on new designs than tweaking old ones, according to a rep I talked to when I called Marin US. I was on the brink of pulling the trigger on one until I found out I couldn't even get one (w/ the changes).
Which brings us back to the original question. Guys are putting long travel forks on hard tails, why not an extra .75 inch on a 4 inch rear?
Hmmm bit confused now,what new designs,I thought (maybe mistakenly) that all the Marin designs (F/S ones) came from the UK (Jon Whyte),are there 2 design teams or 1 team and then the specs set differently for different regions,sorry to be abit off topic here,
anyway I don't YET have a Marin/Whyte but as for tweaks a 5" fork could slacken the head angle to much and give lazy steering which you could offset by fitting a longer i2i shock thus raising the back to compensate,then the b/b may be to high so you'ld have to run extra sag,could get involved here,(hence why I mentioned the Attack trail) however as you can compensate for a 5" fork if need be then I'd say go for it the fork first and see what its like.
Hey - understandably confused. All Marin FS are Whyte designed. The UK and US 02(ithink)-05 were identical in frame geometry. The changes in spec geometry listed in the two sites are due to componentry effects- mainly the change in the fork slackening the angles.
For 06, UK introduced the changes mentioned above. The US quad taras are the same as previous years. I have read a review that the UK main changes are the position of teh BB forward, making you feel more "in" the bike than on it. I opted for a tried and true design, esp. giventhat US closeouts are easily had for much less than importing a UK version.
Thanks for that,I did read once that the 05 model (UK spec had the slacker US head angle) which wasn't liked so much over here and was changed back for 06,I think I've got the years correct so please correct me if I'm wrong on that,suppose its a good thing if they are specing geometry to suit different regions and not a one size fits all.
On another note keep an eye out for the 07/08 Whyte,the 06 E-5 has got some stunning reviews so far with one mag giving it 10/10 but there is a VERY strong rumour that for 07or 08 it will be full CARBON,if the main frames as good as the carbon s/arm thats being raved about then I can't wait.
I posted this in another thread to show the differences in the TARA frames for 06.
NEW UK version
US Version
The new UK spec frames look much improved and should be stronger overall. The lower BB height should make it more maneuverable too. It's a shame we won't get to ride one but considering how un-popular marin's are in the states, I don't really blame them.
I could loan you a 125 vanilla, don't know if you could handle the plushness though...:p
NEW UK version
US Version
Why are they unpopular in the states ????
I just don't get it,they are awesome bikes and good value.
I agree. Despite very good reviews in magazines, Marin doesn't spend a lot of money on advertising and marketing. Also I think some people find the monocoque frame aesthetically challenged. Oh well more for us!
My East Peak (4'' in rear) came with a manitou black that is adjustable from 90 to 120mm.
i ONLY ride it in the 120mm position and have no complaints on the way it rides and we ride some very tight singletrack.
so far the bike has been very good to me,i really like the way it rides.
Yes, that's fonetic
Discussion Starter #13
Well, there you go, I guess I could have. However, since I've broken my second swingarm Marin is giving me a pro-rate deal on a Tara frame! :D :D Think I'm going to try a new Revelation 426 on it. The swap is in the works so it'll be a couple weeks till it's done but I'm really stoked to be getting more squish.
Yes, that's fonetic
Discussion Starter #14
On that note, you guys with the Quad XC frames keep an eye on the underside of the swingarm on the drive side next to the first weld up from the dropout. I had 2 go on me there....
Hey, how did y'all notice the cracks- feel? sound? searching visually? I have this obnoxious click under initial weight(supposedly the bb, per the lbs - but they are looking back into it today) and have not found any indication of cracks on my tara....had the bushings tightened, check shock mount bolts, etc.
Yes, that's fonetic
Discussion Starter #16
First one split wide open, fortunately not on a fast downhill.... no telling how long it was cracked. This one has a verrry small crack I found upon regular inspection/cleanning in the same spot. Another photo....
Yes, that's fonetic
Discussion Starter #17
BTW, I'd still buy another Quad XC if I wanted a lightweight racetype bike, I just have been lusting after more travel. With their pro rate policy and 5 year frame warranty and lifetime warranty on pivot bearings.... Marin rocks.
whoda -
Well, sorry that my review wasn't done in time for you to build the anticipation - glad to see that you are getting the upgrade. you won't be dissapointed. I would suggest running sag at 20% of whatever setting you are using, otherwise climbing can feel very slow over rocks/roots. I think it loses that momentum-over-square-edges if you are sagging too far into the travel.
You can expect a half degree more slack headangle with every inch of travel added.
Yes, that's fonetic
Discussion Starter #20
CharacterZero said:
whoda -
Thanks, I'll post a review when it's together.
1 - 20 of 20 Posts
