1 - 3 of 3 Posts
· Registered
Hi guys,
i'm having difficultly trying to adjust the upper/lower limits on this bike, i cannot get a screw driver from any angle to connect with the limit screws?
As you can see someone has tried to make me a sort of angle philips screwdriver but this still not small enough!
there must be an easy way to do this - any ideas??
thanks
Darren
· Registered
Use a long flat bladed screwdriver to get inbetween the swing-arm from above.
It may require a bit of guess work so make the limit screw adjustments in small steps. Make sure to click the shifter all the way to the end when you do this.
1 - 3 of 3 Posts
