1 - 4 of 4 Posts
noMAD man
Seen this on the Marz, Manitou, and Fox 20mm setups at one point or another. It is usually a result of the pinch bolts being over torqued. It is very tempting to wail on those bolts even though they're quite small. As yogreg stated, you'll need to get that replaced...new lowers.
Meh.
Jonnyboy said:
Hi
I own a set of 2005 manitou sherman breakout plus forks. They have begun to crack at the right axle clamp
Hi have attached photos. Has anyone else had this problem and what should I do? Is it ridable?
Looks like you tightened them too much. You really only need them snug.
1 - 4 of 4 Posts
