mtnbike1971 said:
Andrew, Sorry about the mix up.
I HAVE the R7 Super Lock Out (have the remote Click It system but never installed). I DO NOT have the Platinum w/SPV. Sorry and thx for the help.
Rob
No problem, Rob. We're all human. Hey, I should have spotted it sooner.
Okay, two possible suspects;
1) lever orientation - the lever can be removed and re-positioned. It might be a case where your's needs this attention for whatever reason (do you use it alot???). This is done by using an allen key to remove the bolt holding down the lever (top, middle of the lever). Be CAREFULL - there are two small balls that are spring-loaded, so care should be taken here to avoid losing them. If you're really carefull then the balls and springs will stay in place. Once the lever is removed, turn the hex-shaped post (the one the lever was on) all the way CW, as to lock the fork. Check the fork to see if it now locks or not (more in #2 below). Once you have the post turned full CW put the lever back on so it is oriented as far CW as it can go
without hitting the crown! Once that's done, put the screw back it and ride.
2) oil level - if you followed #1 above to no avail then your problem is undoubtedly oil level related - not enough oil. Manitou's TPC lockout systems, in any incarnation, at any time frame, have
always been sensitive to oil level. It's just the way the system works. In this case I must ask - are you mechanically inclined??? If so i'll give you instructions to check/re-fill your damper oil. Otherwise you're best to take it to an LBS and have them do it.
Let me know.
